1 - 8 of 8 Posts
Tony McKellar
Refer to the thread Monty started ref. building a SSO car,there are pics to illustrate your querry.
how are you guys running lines when you're using a wastegate as the blow off valve?
What? Are we looking at the same picture....
You BOV should be referenced to manifold after the TB blade. Your WG should be referenced to manifold pressure somewhere after the outlet of the compressor, and usually into the side of the gate, depending on the gate you are using. Some have a side port and a top port, don't hook to the top port.
1 - 8 of 8 Posts
