1 - 12 of 12 Posts
I have a turbo 400 with an aluminum drum, 300m input shaft in a stock case. I have roughly 200 miles since having this thing built. At first when running it sounded like a noisy convertor or a small clunk on revolutions. The last time I started it it had a screeching/ screaming noise coming from the pump area getting louder with rpm to move. I pulled it out and pulled it apart. Found metallic brass looking in the oil and noticed my stator tube bushing are shot. What would cause this? Thanks for all of the help. Gonna attempt to fix this on my own.
The bushing looks a bit beat up but as already stated, the converter should have its own support bushing and the front tube bushing doesn't look destroyed enough to make a mess of your oil so keep looking.
Hutch
Discussion Starter · #7 ·
She’s apart. Everything looks good other than the pump bushings. Can definitely tell it only has 200-300 miles on it.
264522
264524
264525
Discussion Starter · #9 ·
Convertor just got sent back. Does anything in the pictures look bad?
It's hard to tell when you don't have everything apart. As Hutch mentioned, the debris in the picture you posted in your other thread came from somewhere. You should continue to disassemble the whole thing. I'd be curious as to what the pump looks like after all of that debris went through it.
1 - 12 of 12 Posts
