1 - 1 of 1 Posts
Is there a way to delete the band and do away with the engine braking? Trans will be full race have machined both forward and direct to 5 clutches. I have welded second valve from right on valve body and removed accumulator spring to firm up second. We welded governer full open also. I was thinking using a 1/8th plug and remove the servo piston. Any other mods need done?
1 - 1 of 1 Posts
