1 - 20 of 20 Posts
RED ROCKET
i see tunnel rams short and tall...most i see for a spread port motor bbc are 10inches tall....what would it affect if i had one built that was 8 inches tall?at 8inches i could put the dominators under my hood which i do not want to cut.
combo is a 15.1 632 with 1802 big dukes .
thanks for any thoughts on this.
who would you have build it?
RED ROCKET
Discussion Starter · #2 ·
also will i see any hp increase from my single carb?
The whole point of a tunnel ram or sheet metal intake is to make the engine most efficient in a given rpm range. If you shorten the runners or decrease the plenum volume then you are going to alter the characteristics of the intake - most likely for the worse.
Length and RPM kinda work hand-n-hand. They are designed per application, just for this reason. Shorter runners like higher RPM for the most part, just depends. Whats the total length from seat to plenum?
T-flow
RED ROCKET
with a 632 you got gobbs of torque, that 2 inches just going to move the power band up 2-300 rpms
i could deal with that...it also has 600hp worth of juice i spray every pass.
RED ROCKET
Discussion Starter · #8 ·
maybe somebody will post that has done this before..i know there are some high end builders on here.
Assuming an initial rpm taget of 7800 for the original intake and set of heads that would put runner length at ~97000/7800 = 12.435" lopping off 2 inches would give a target rpm number of 9300rpm. Pretty big difference
RED ROCKET
Discussion Starter · #12 ·
i used the websiet above to get info..seat to flange 5 inches,flange to guide 3 1/2...using numbers and averages i came up with 11 1/2 total length for my current head and intake...motor runs out breath right now at 7500.it will go higher just doesnt seem to make any more power.
thanks for the help and keep the info coming..i want to make the right decision for this setup.
You might try put a spacer in the plenum more volume helps also and is the easy thing to do
RED ROCKET
Discussion Starter · #14 ·
i want to go to twin carbs for more power..i have a 1/2 wood spacer now .i tried a 1inch spacer and it ran the same.
How big in your intake now? We have a 15to 1 632 with 1802s with a 2005cfm tb and a VERY HEAVLY ported single intake and makes power way above 7,500 rpm....
RED ROCKET
Discussion Starter · #17 ·
its a big duke tall deck from brodix...1500cfm carb.
What is the porting like, has it been worked over any? And is it one of the older intakes with the clover design or one of the newer with the open design?
RED ROCKET
Discussion Starter · #19 ·
was a clover leave at the top but it was removed and it has been ported by a race shop(brad west).
always been told 2 carbs would make more power and thats why i am considering it..i shift now at 7400 and both foggers on its pulling good..be nice to pick up a little motor power and mph more.
These intakes need more than just a little porting, they need magor work done to them to get the air they need. I'm sure with some more work on the intake that it would pick up some more with out having to go with duel carb set up and having to replum your set up. Could also go with efi on there and get a bigger tb(air moving thru there) on the intake.
1 - 20 of 20 Posts
