1 - 20 of 26 Posts
Well I just got a new 88 firebird project , it's been sitting in a garage for the last 10
Years without the motor in it I got it and now need to put the puzzle back together , I'm having trouble
Figuring out the tpi set up . Is there any online help to show how to put this back together
After A CLOSER LOOK I'VE SEEMED TO misplaced the MAF is there any way to bypass it and
Go speed density
Cost you 10X more to swap to SD then to buy a reman maf.
I think you can adapt the newer stle MAF to that old engine as well. They flow better and are more reliable.
I once tried to put a basket case TPI back together with a friend who was doing it for a friend of his. It was a mix and match basket of SD, MAF, pre-87 and 87+ parts, and we couldn't put Humpty Dumpty back together again without spending more time and money than it was worth. I hope you have better luck!
I agree 100% wouldn't be worthe the time or money to
Swap he asked if it could be bypassed.. If that's all ur lacking buy one. Otherwise I'd go carb probably have less issues.
Discussion Starter #12
Well this all seems to be there it's a basket case but not exactly a humpty dumpy.
The car is actually pretty nice just needs the motor put back in .hope to get started on it later this week . Let's keep our fingers crossed .I a precise the help
I dunno. I played around with a Jag convertible for about 8 years. Did a 5.7 TPI/700R4 swap and had a blast. Stock TPI peanut cam with a 1.6 rr, bolt on intake and runners. Stock tune. 2800 stall converter, 3.23 posi, and the 4010lb pig ran [email protected] on legit dot's and had great street manners, decent on fuel, and was an absolute blast to drive. Never had to work on it. Big heavy car (4010#) and a motor that made tons of torque, made for a great combo. She was all in by 5500, but on the street, that's not an issue.
i remember working on the TPI setup in the wifes old 88 formula 350
totally impressed with it and shocked me at the torque it had
i put edelbrock TPI heads on it, and it really woke it up
that thing would do 100' long peel outs with no problem
very responsive down low and coming from a BOPC (buick/old/pontiac/caddy) background, it was as close torque wise as you could expect from a SBC
easy to work on too
i wanted to change the cam on it too, but we had to move and gave the car to a friends son
1 - 20 of 26 Posts
