1 - 10 of 10 Posts
I would appreciate any info on the legitimate cause(s) of "tuliping" intake valves??
Have a 900+ HP SBC (blown) with 3 tuliped intakes and a 3000HP BBC (twin-turbo) with the same scenario, 3 intakes tuliped!
Thanks, Gary in N.Y.
P.S. There is no damage to either unit on the exhaust valves, none burnt/none tuliped. Will keep valve "brands" under wraps temporarily, I don't believe the brand to be a factor?
The valve brands, therefore materials and construction make a lot difference. Put a good flat faced titanium intake with some margin in it and it will be fixed, barring tuning errors.
Do all of the intake valves have the same margin, or close to the same? As pointed out above, lack of margin and excessive heat ate typical causes of valve tuliping.
If it is 'heat' seems odd that the exh valves were not showing signs of heat stress. Without seeing the valve, maybe a combination of seat bounce, large diameter & a thin head.
Too much timing or too hot of a spark plug, are typically the causes of problems on the intake side. A rich mixture can aggravate the situation.
1 - 10 of 10 Posts
