1 - 5 of 5 Posts
Material of rollcage tubing is unkown. It sonic checked at .088wall. Would there be any posibility that this wouldnt be chromoly? The car was built about 10years ago.
Senior phuckstick
It's just a guess, but I would think it is C/M. Not too many people Tig to start with. If they were going to Tig a M/S cage, they would likely make sure it would pass a sonic test.
If the sonic tester was calibrated I would not be so sure about chrome moly. .088 not a normal thickness. .083 chrome moly is normally dead on when checked with a sonic tester. Sounds more like mild steel .095 to me. I do tig all of my cages wheather cm or mild.
Drill a hole, take a drill chip and heat cherry red with a torch. Quench with oil or water, then bend if mild or break if cm. The 3 points of carbon in the cm makes it very hard and brittle. This is why you don't want to over heat a weld joint when welding chrome moly.
Red neck science baby!
Try it and let us know what you find............................Toni
1 - 5 of 5 Posts
