Has anyone else had problems with tubes bursting . We have had three go out in the last month two different cars. Three different wheels.
28x10.5s .
What could be causing this ?
Two of the wheels are single beadlocked with screws on the other side . The other wheel is double beadlocked . Don't know the exact size of the hole for the valve stem but around the base of the stem the tube is fine . The split is starting elsewhere not close to the stem on any of the three tubes.
This may be a silly question, but do you have the right size tube?
How wide are the wheels?
Something seems a bit off, but it may be hard to diagnose without looking at the tube/tire/wheel package in person.
