1 - 4 of 4 Posts
Fox body with a tubular front end. Would 1” moly be suitable for hanging (supporting) twins. The front end is mostly 1 5/8 with 1” kickers. I’m a bit concerned about all that weight hanging off of it so I’m thinking about adding two more supports. Thoughts?
I would think more supports, or one support made of bigger OD material might be something to think about, especially if the supports are fairly long (the longer the support the more twisting/rotating leverage it can generate at the weld joints).
Might even want to think about adding some small OD diagonals to the supports to spread the load over an even larger area, especially if it's .058" or .065" material it's attaching to.
1 - 4 of 4 Posts
