1 - 20 of 20 Posts
They have the Lamborghini Festival club here in Houston, there are some bad ass twin turbo cars but I doubt any of them are 2,000 HP.
Sure it's a totally stock Coyote swap, slightly massaged Voodo heads, couple of turbos and slight tuning.....pretty much stock! :p
It’s from a roll, but that’s 220 in the 1/4 at 3500 pounds. They probably aren’t able to apply 3500hp, but they are capable of it and put it down in the 1/2 and 1 mile events. I’m not sure who the new craze is, but proline was building all the custom parts a little while back.
Discussion Starter #10
Its not the 1/4 - they actually set the traps up further down the shut down area
I know I was skeptical of buying my lambo because it was ONLY 1200HP on high boost. It is fast as hell I can't imagine any of these huge builds that UR is doing. 3500 seems impossible, that is what top fuel was putting down not long ago. I have never seen a dyno slip, so I couldn't confirm it.
Q(t)=ṁCpΔT
3500HP in a cast block? Yeah, right. They're fragile in the webs.
They make the number once, then the owner prints the dyno sheet out and frames it. Then they back it down 30-40psi and put it in the car. I doubt the owner could even load the high hp tune if he wanted to.
Go to a Runway Rivalry event in TX. Those cars are impressive as hell. Insane. An Audi R10 has recently been the dominant force also built by UGR.
Nitrous Junky
If it has the new 50K billet block I can see it. Stock block comes apart around 2000-2400
1 - 20 of 20 Posts
