1 - 19 of 19 Posts
I just got some rear Afco bgs an afco tec guys said start ext 10 clicks from tight an compression the same way
There are 38 clicks on ext taken 10 away is like 3/4 from thigh an comp 24 clicks - 10 would be 14
TRZ on hear says different 1/4 loose on ext an 3/4 tight on compression!!!!
I'M NOT SAYING WHO'S WRONG OR RIGHT BECAUSE I DON'T NO!!! BUT I JUST WON'T TO NO WITH WAY DO I START......PLEASE HELP THANKS
Remember that Afco shock settings are commonly referenced from full STIFF, not full loose like other shocks.
afco said start stiff on ext an go back 10 clicks an trz says start loose on ext with works better? I no all cara are different so it may very I have a G body if this helps? Starting stiff at about 28 an going all the way loose to 10 or 12 is a long way off this is why I'm asking...I no trz knows there shit when it comes to g bodys but these people make the shocks
On a Radial ( thats what I am going with from TRZ's answer) it will like a loose ext and a tight comp. Remember it now 2 two clicks for what used to be one.
so go full loose then tighten 10 clicks on ext from full loose
go full tight and loosen 6 on comp from full tight
A bias tire will like a tighter ext and less compression than the TRZ setting so it can get up on the tire
Discussion Starter #15
The new one I got have 24 ext 38 compression
Now let's try it like this Jeff...Loi
Ext 10 clicks from loose is 10
Com 6 clicks from stiff is 32
Discussion Starter #16
Ok that's the difference rite there because I have slick is why they said 10 from stiff on each!!!! Thanks Jeff your the man...Loi it been fun cheating on this matter with u
With your bias tire I would start closer to a 50 /50 setting
Man My head hurts LOL
Discussion Starter #18
Jeff mine does to....Loi its confusing with so many clicks an different ways to approach it!!! Then u hit me with the double clicks I said this gone be a long nite......thanks for the info
Jeff's right, sorry, we work with 99% radial cars, so I sometimes just assume people are running the radial. With the slick, you need SOME tire speed, so a different setting is needed. Sorry about the confusion.
1 - 19 of 19 Posts
