yesterday we made several passes. we were running the car just on one system. i was not reading plugs on the particular 3 passes i am about to talk about. plugs were pretty close from last time to track. i had 28/22 in the fogger at 5.5 lbs. i was running down the track at 20 degrees. made 2 hits that were close in time. i added 2 degrees back into it to see if it liked it and it picked up like 1.5 mph. i think it spun just a little to maybe throw et but it was trying to light the candles. small flames started to come out but was kinda going in and out there were not constant. on the passes before i added the 2 extra degrees back in there were no candles that i am aware of. i will probably take another degree back out since the car only picked up one and a half mph from 2 degrees added back in. any thoughts on the candles coming in an out? and mph change from adding timing?
this is a afr headed sbf 418 on 1 fogger
hope that made sense
