we are out of jet options from the big shot dominator plate kit -
we were running 102N /91F @ 6psi at 21* (taking out 14* from 35*) - but never really got a timed pass to see what that did
SOOOO - we have a hot grudge coming up - so we figured why wait - just go bigger
- we think we have been babying the motor
so I wanter your thoughts on a 110N / 102F - @ 5.75psi - took out 1* more to 20* overall - (15* from 35*) -
an initial blip or two of the button in the garage - plug looks just slightly rich - but it sounds ferocious when it hits
540ci - merlin block - canfield heads - PRO Systems 1100 dominator - nitrous friendly cam with about .680 lift - (its not a screamer rpm motor) - about 155 psi cranking compression - powerglide / 32 x14 x 15 in a long ricer body
anything else you think I can do as a starting range to try this combo
