1 - 11 of 11 Posts
Hey, guys im new to this form, and also to Nitrous, any input will be appreciated. The other week I had an empty nitrous bottle in my trunk, hooked up to the supply line, and blow off line. I was at the parts store, i open the trunk to put something in the trunk, closed the trunk, and less than 5 mins later, as i was driving, i smelt something burning, the car filled with smoke, open the trunk, the carpet was on fire. It brunt 2 holes right around where the supply and blow-off line go through the carpet. Thank god i have a fire extinsure. I dont understand, the only places where the carpet was brunt though, was around those 2 lines. How the hell did this happen? The only shady thing is, I had the trunk open while i was looking under the hood, part of me thinks someone through a match or something, but i didnt see anything like that. And if it helps, it was hot that day, but the bottle was EMPTY. Thanks
Sounds like the nitrous supply line or the blowdown tube were touching an electrical power source, maybe rubbed through a positive wire somewhere.
I'm using a -8 braided line as my blow down, i have extra line. I Nitrous line is run outside the car, and the blow down, is drilled straight down going to outside of the car. So you think I have a short positive wire some where, and it grounded againest the braided line? Thanks
Banned
I bet one of your lines came in contact with a hot terminal somewhere and brought +12 volts to the back and shorted to the floor where you have the lines going through. You need a LOT of heat, or a flame, to start a fire.
Thanks, guys, i have the lines going through rubber gromments, i have to check all of my wiring by my lines.
Banned
If you have a bottle heater on your bottle where does its power come from? No matter what, you sould have a fuse on it, as close to the power source as possible.
Don't see how you could have had a fire if your lines are going through rubber grommets. Maybe someone did toss a match or cigarette butt inside your open trunk.
1 - 11 of 11 Posts
