1 - 10 of 10 Posts
Busy being a cunt
Transparent heat shrink tubing with adhesive. What's any good, what's not, and what are you using?
This is not for electrical use, it will be used to seal a low pressure oil line so the adhesive needs to able to withstand oil.
Busy being a cunt
Is that something that you've used, or just a "cut n paste"?
Busy being a cunt
Discussion Starter #8
Jaycar sell it but I don't know if it stands up to oil.
I bought some elsewhere online, thanks.
I have not used these. Tube/line ID, pressure and temperature might be good info to share.
Thanks.
I would guess any talk of those being oil resistant is on the outside, not actually sealing oil from say a pipe from getting out.
I guess I'll find out, I'll mock up a test piece before I put it to actual use.
This. The adhesive is nothing more than hot glue.
If the wire or line flexes much, it will pull apart. I have to re-heat terminal covers on large cables every now and then, due to flex.
T/S 368E
Not sure of the application, but why is it too hard, expensive to do it right the 1st time???
I use all kinds of heat shrinks, patches & wrap on sealers, and if humanly possible, I always try to fix the issue,
before risking failure when this patch fails???
I've even used 2-3 layers before when the customer was being an idiot and didn't want to pay to have it done right.
Good luck.
1 - 10 of 10 Posts
