1 - 13 of 13 Posts
im doing a 540" with twins on gas for d/r.this is all going into a third gen camaro.the weight will be between 3400-3500lb. is it better to run a t-400 or glide? any suggestions?
x2 on the glide
i guess the verdict is glide then. thanks!
Custom Engine Shop
Mike,
The guys are giving you good advice, go with the 'glide.
Go with the glide
hmmmmmm.......Glide!
Discussion Starter · #12 ·
just curious but the glide because of the gear ratios? or can they take more power?
Custom Engine Shop
With a turbo you should not need the gear (of a th400) to get the car moving. Plus the lower gear will help load the turbo.
1 - 13 of 13 Posts
