1 - 3 of 3 Posts
I have a turbo350 and 400. Which would be the best to build to handle a 500hp? Also wondering on what brand of overhaul kit should I use? Thanx for any info
If you don't mind, what do you recommend for parts and rebuild kit? My engine combo is 4bolt 355(all machine work), scat crank(crank scraper, windage tray, 6.25 balancer), forged I beam rods(5.7, floating pins), forged speed pro pistons(9.25cr,coated skirts), .488 int 510 exh duration 234 int 244 exh @ .50 303 int 313 exh adv 106 lobe sep, vortec heads (8062's, fel pro 1094, 1.5 rr, springsmatched to cam), rpm air gap, holley 750 vac(tuned), nos plate(175), unknown billet h.e.i., headers 13/4 prim 31/2 collector(to big at this stage),7.5 rear end(3.42's, 28 spline axles, 02 WS6 limited slip). In process; 3.73's, 1.6rr, spray 250 (150 in 2nd with 100 in 3rd) and car is on diet plan.
1 - 3 of 3 Posts
