1 - 4 of 4 Posts
I did a search and only found one thread on this subject...
Hutch,I was wondering what typ fluid you use in your racing transmissions????
I was always a typ "F" guy but i have been hearing from some other racers that the dex III is a much better all around fluid???
have you done any research on this???
Keith
Well I hate to make suggestions , I had a great fluid but the refinery that made it went buns up, it was basically a 10W30 type F.
I have customers that run with success mobil1 ,torco and royal purple and I can honestly say I havent seen much as far as clutch wear decrease but gear wear is slightly better in high hp applications so far.
Others have run type f ,mopar atf4 and numerous dexron oils under several labels.
The only research I have done is to see if the transmission shows an improvement in wear items after a season of racing. The new oils being tried this season are the amsoil and lucas racing fluids. Im hoping I will see a reduction in some of the gear wear in the powerglides without being too slippery and causing clutch problems, but only time will tell.
Take care ,Hutch
no to step on your thread hutch,but i have been running shaffers synthetic for the last two season and have had great results with it,i never had problems with the amsoil supershift either,steve
1 - 4 of 4 Posts
