1 - 7 of 7 Posts
turbo 400
dont wantt o try the tracter fluid just yet . is type f the next choice in line??
i feel i need to get the rpms down just 100-200 rpm and i thought a thicker better fluid might do that
In a T400 , Type F , typeF mixed 50/50 with John Deere Hygard works well. Also just be sure you have a screen filter in the trans before going to the heavier fluid or you will have a meltdown.
Hutch
Which part of what I said are you wanting an answer for?:confused:
Hutch
I would guess the screen filter comment. You've probably given you're opinion on screen vs paper filters 1000's of times, but a quick half-assed search didn't pull it up. From your comment I'd assume the screen type is less restrictive and the best choice in all applications.
1 - 7 of 7 Posts
