1 - 5 of 5 Posts
I have seen some car's not run a cooler for the trans and just a looped piece of tubing. Is this okay if your not hot lapping and do not run a bracket car?
from across the pond...
yes if you use good quality synthetic oil, but personally i would never run without a cooler. Converter temps go through the roof without some form of cooling.
Confused Racer
Do you tow your car around? I used loop my altered sice it was towed and we only ran every hour or so the cooler would do nothing. If you are driving back use a cooler it can only help.
IMHO, ALWAYS run a cooler, the biggest you can fit with the space you have to work with. There are no drawbacks to using one. Just make sure it's where the engine fan can pull air through it, or mount a smaller fan directly on it. Your trans will love you for it later......
1 - 5 of 5 Posts
