So I have a B&M 11"x8"x1.5" tranny cooler... where I mounted it this time, It doesnt get the pull from the fan on the radiator. I am going to build a small shroud and a fan setup for it.
http://www.summitracing.com/parts/BMM-70266/
The two fans I am looing at are roughly 435 CFM and the other is 625 cfm... The 625 will be tough to make fit as it is 9.72 inches total diameter and I only have 8 inches on the cooler at one point.
And the 435 is roughly 8 inches total diameter.
Is the 435 CFM fan enough to run the tranny cooler, or do I need more?
