1 - 3 of 3 Posts
On the door car with the turbo 400 I noticed a small spot of tranny fliud on the garage floor. Being the tunnel is off it was easy to find out where it was coming from. It is dripping from the end of the tranny brake. I have no problem taking it out and replacing what ever is wore but I never had one apart and would like to know is it an "o"ring or some type of seal?
Doest it go where the modulator valve used to be, RH side front of the trans with a little fork bracket holding it in?
If it is there is just an o-ring in there.
1 - 3 of 3 Posts
