Those that use a roof socket to pull your car back, how long are your tow lines?
Thanks Rick
Thanks Rick
Thanks Rick
I believe it was 1". I used solid clevises from McMaster Carr and welded them in both ends. I just remembered that I ended up changing the clevis on the end of the bar that hooks to the car. When I get home I'll take a pic and post it to show what it looks like now.Barry
What size tube did you use? I can't make out the end that hooks to the back of the car, is it a clevis of sorts?
Thanks Rick
Here's what the clevis looks like now. The bracket on the chute mount slides in between and a pin drops through. Works like a champ.is it a clevis of sorts?
I could if I needed to but I park the cart in front and winch the car in. The nicest thing about the push bar hands down is the fact that I'm in control of the car, I pick the lane in staging that I wanna run down and I don't EVER have to worry about running over the strap. No confusion. Just push me and I'll stop when I'm ready to.Barry,
do you push your car in the trailer with it,
Same here...have used it two seasons...works great. I had one of the pins put on the car end. I think maybe you can order them that way too.The Jerry Bickel retractable straps are awesome. I've had two, only because I backed into something and broke the first one after several years of service.
