still trying to get this timing right, today we warmed up motor, unhooked and plugged vacuum advance, then i had my dad rev to 3000 rpm, timing was 42, so i turned distributor until we had 36 at 3000, then checked initial timing, it was around 16 or so, with vacuum advance hooked back to manifold vacuum, i only had 22 at idle, so i turned allen screw in vacuum can until i had about 28-30 at idle, did i set this the right way or am i way off?
