1 - 4 of 4 Posts
What's the smallest female torx socket made? Do they make one smaller than an E4?
I have a couple of screws in a steering column of a Sonoma that I can't find a bit to fit.
Thank you for your help.
All of my kits only go down to 4,are you sure the body of the socket isn't hitting something.They make deep inverted torx's just for steering columns.Most of the chevy's I've worked on used the 4.
It must be the E4 then. There are two different size screws; one I got loose using the smallest socket I had, like a 5/32", but the other one is smaller. I guess I'll have to buy an E4.
1 - 4 of 4 Posts
