1 - 7 of 7 Posts
I'm putting a turbo 8 to 10 pounds on a mild 350 chevy, in 71 monti carlo, I have a brand new 10 inch 3600 stall converter, but it doesn't have a balloon plate, has anyone tried a converter without the plate, with any luck?
Stall speed depends on power level. If it's a cheap generic converter it will probably drive thru it and possibly take out the thrust bearing too. If you try it I would keep a close check on crank thrust clearance.
It's a B&M holeshot
1 - 7 of 7 Posts
