Car is a 2000 Trans Am, 400 hp on motor, 200 shot. Long torque arm, TRZ relocation brackets. Rear suspension is all rod ends.
If I understand correctly, the only way to change the instant center is to change the length of the torque arm. Some people say there are minor changes from adjusting the front of the torque arm up and down. So would moving the front of the torque arm up or down transfer more weight to the rear wheels?
From research, I set the car to -2 pinion angle, torque arm 2 degrees down hill to the front, and lower control arms 2 degrees down toward the rear end. This has netted me a best of 1.43.
I'm getting ready to check everything again and was wondering if these angles should be in relation to the chassis or the ground. It makes more sense to me for them to be in relation to the chassis. May car sits with some rake to the front and with the lower control arms set at 2 degrees toward the rear end it's about a 4 degree difference to the chassis. The torque arm at 2 degrees down hill to the front is parallel with the chassis.
Thanks for any help.
