1 - 14 of 14 Posts
i have a third gen camaro with a 9". torque arm is hitting trans tunnel. does anyone sell a different bracket that bolts onto the rearend to compensate for the offset? i have a torque arm and dont want to have to buy another. if there are any dealers let me know because i need to get one asap. thanks, mike
FFW crew
i made my own , then got a new arm from Burkhart!!!! kind of a waste of time!!! Burkhart all the way ,no clearance issues what so ever.
does he have a web site?
Discussion Starter · #4 ·
did they sell you just the bracket? how much?
I know my spohn one has a set of holes for stock and 12 bolt, and another pair of holes for 9 inch and dana 60. The holes are probably something like an inch maybe more apart from each other.
burkhart builds their arms to clear the floor with the 9 inch, they will ask you what you're running when you call them up
Discussion Starter · #11 ·
im going to measure the eyelets from center to center and then make some calls. thanks everyone.
if i use the old bracket with the slight offset in the torque arm will it make a bind?
Discussion Starter · #12 ·
its modeled off a spohn arm if it matters.
Discussion Starter · #14 ·
well i used a bfh and got the trans tunnel all clearanced. onced cleared i used a steel plate to reinforce the area. thanks to all for the advice! mike
1 - 14 of 14 Posts
