1 - 10 of 10 Posts
what pressure's do yall set your torches too, people keep messin with our one at work and it never works right.
Guess it depends on how big it is, but I set my oxygen about 40 psi and the gas about 20 psi. It's a pretty decent size Harris, don't recall the model.
How's the tip? If it gets beat up/orifices closed up it will not burn straight and clean.
god only knows i'll have to clean it and reset it i liked it in the teens and 30's worked good at my house, but the piece at work always veries pretty bad
For a med size cutting torch Set the Oxy at 35lbs and the Acet. at 7-10 lbs
30/7 here.
Discussion Starter #8
thanks guys just have to keep all the others hands off it
1 - 10 of 10 Posts
