1 - 9 of 9 Posts
T/S 368E
I just did the same thing. Bought the cheap little screw in locater.
Engine is running also, but I wanted to get exact timing before hitting the fogger & accurate records.
I bought a non fouler adapter, threaded with a 3/8" - 16 tap and then got a ling 3/8" - 16 bolt and ran a die on it to lengthed the thread and use that for a dead stop on a complete engine.
Turn the engine over slowly until it stops, mark the balancer, turn the engine over in the opposite direction until it stops and make a mark. 1/2 way between thse marks is TDC
I just switched over to a crank trigger setup from a stock distributor and stock timing pointer. I used one of the screw in the spark plug hole top dead center locaters. It worked out real well and actually matched up perfect with the stock timing indicator.
I've made these locators from old spark plugs, by breaking the porcelain out, the electrode off and running a tap for a bolt through it. I then use a long bolt and nut, the nut is a "lock", and use that to find TDC.
I usually round off the end of the bolt as well, so the piston isn't making any contact with any sharp threads.
X2. This worked real well for me!
this is exactly what we do....lol
1 - 9 of 9 Posts
