1 - 3 of 3 Posts
I think I know the answer, but I always appreciate a little confirmation.
I believe that as the rear end ratio gets closer to 1 to 1, the amount of tooth engagement increases. And as the amount of engagement increases, the strength of the gear set increases. Am I correct? I am wondering if that is why Pro Gears tend to not be available with a ratio numerically lower than 4.10 to 1? The tooth engagement makes it unnecessary? Take care. Tom Worthington
Moderator
The higher numerical ratio the smaller the pinion becomes. The smaller the pinion has to do more work and therefore is generally not as strong. I assume you referring to the availability on the 12 Bolt GM ring and pinions.
There isn’t enough demand and a need for higher, (lower numerical) ratio, 12 bolt gears. Many other gears are available in the “Pro-Gear” material, that is 9310 alloy. The basic 9” Ford sets are available from 2.91 to 6.50 ratios is sizes from the 9” to 10” pitch diameter sets .
The availability of “Pro-Gears” reflects the demand by users for of a specific style differential.
Thank you. I'll take that as a general confirmation about my strength vs. ratio belief. :D And I definitely see your point about the lack of demand for those ratios, in a 12 bolt. It's covered by 9" applications for high hp. Take care. Tom Worthington
1 - 3 of 3 Posts
