1 - 18 of 18 Posts
Is this too much tire crush and does it hurt 60' times. 29x10 Hoosier with 10.5lbs air. 4 link with 87% anti squat , foot brake. Just curious of opinions.
Yes that is not crush that is side wall Kill, but a set of radials it would kick ass with I bet.
I kill parts
It does seem to be folding up the tires pretty hard according to the settings/tune you're providing. - Out of curiousity, have you verified the tire gauge you're using lately?
Discussion Starter · #7 ·
Yes, I used different gauges and they were within 1/2 pound.
Discussion Starter · #8 ·
Next question would be, should I take some off the hit out of it. I/C is now at 40" long and 7" high. My next lower setting would be 53" long and 4.2 high. I think it it too long and will not be able too hook. Its a 98" wheel base. The other lengths between the 40 and 53 are too high with more anti squat.
Banned
I wouldn't touch the 4-link.
I'd start increasing the air press OR tighten up the extension side of the shock a bit.
Radial, radial, radial. LOL When I see a tire like this, it if it has good double adj shocks loves a radial with lots of air pressure.
Discussion Starter · #12 ·
I have single adjustable QA1's in the rear set on 3 clicks. I'll try going higher in air pressure to see what happens. My brother has a 315 radial I will try in a few weeks to see how it likes them If it runs good with them then I'll get a set of 295's. Never had a drag radial, always a slick.
Foot braking would tell me a auto. You will need some doubles with the radials most likely
1 - 18 of 18 Posts
