1 - 4 of 4 Posts
im looking at building at just under a 14-1 sbf motor. keep getting told its to much to spray it? any truth to that or?
EFI/N2O JUNKIE
Unless you are using junk parts the people telling you that just want to try and stay faster than you. ;)
Between 13 and 14 to 1 seems like a good safe place to be. If you are running heads-up in a jet-limited class then you'd want more compression and have a more finicky tune.
thanks... it will be a all forged 393 in a stock block. and i was thinking of spraying around 150-200 through a single stage plate kit. its more of a grudge match car then anything.
1 - 4 of 4 Posts
