1 - 3 of 3 Posts
I'm going to be needing some new tires soon.I run a N/A SBF on a good track with pretty good air I can go 1.24-1.26 60ft.Like most N/A combos I try to hit the tires pretty hard.I'm thinking about trying a Hoosier 275,but my money is pretty tight since I've been out of work untill a month ago so I would like some good info if possible.My combo is in my signature but it's stk susp.2950lbs,glide,,,etc, anyway I wanted to see what I could find on here or anyone else is running them on a N/A combo.
Nothing wrong with going radials, but don't expect the same suspension tune and converter from a slick car to work very well with a drag radial..JYou can't hit the radial AS HARD as a slick and will sacrifice e/t because of this..
1 - 3 of 3 Posts
