1 - 1 of 1 Posts
We offer a couple options if you would like to raise your ride height in the front that many aren't aware of. Our arms lower the car about 1 1/2". For those that only want about a 3/4" or no drop at all we offer these:
These will bolt on to the coil-over style control arms. Of course the shorter one would raise you about 3/4" and the taller one returns you to about stock ride height. If you are currently using a t-bar mount we supply you with the spherical bearings to replace the t-bars.
Also a feature we have been adding, over about the past year, allows you to switch from a stock style spring to a coil over set up without having to buy new lower arms. Using the cup pictured below, simply unbolt the cup and use either one of the adapters above and a bearing type coil over shock or simply use a t-bar type coil over (like the QA1 GMP kits) and bolt it directly to the plate.
1 - 1 of 1 Posts
