Was wondering if any of you guys were using titanium intake valves using big shots of nitrous , also can they be used for the street as this car will run in nmca true street class ? thanks for any info...
Yes, Ti intakes & exhausts spraying about a 1,000 on average. I can't speak for street car usage. Generally titanium valves are rated in hours of life. If you call Eceldyne they should be able to tell you what you are asking. http://www.xceldyne.com/
Yup, designed for long life as long as the variables stay in line, higher spring pressures reduce life, but what is the intended life, look at a nascar engine, man, 500 miles of WOT operation at nearly 10K RPM, Ours should be fine....
