1 - 1 of 1 Posts
I've been playing with the tire pressure in the bfg T/A 255/60r15's on my ls powered Geo Tracker. This is a car with very little weight on the rear tires. I believe the wheels are 8" wide.
The outer(edge) rows of tread aren't totally flat with the inner rows so I'm not sure how much contact I should expect from them. I went as low as 15 psi and the tires still look like they could have 40psi in them. No bulge at the bottom. This is a car that only called for 23 psi from the factory which is about the lowest I've ever seen.
Judging off these burnounts... Should I try lower than 15 psi?
1 - 1 of 1 Posts
