1 - 12 of 12 Posts
WHAT IS THE BEST BOX TO USE FOR PULLING TIMING OUT WITH A CONTROLLER AND ALOT OF SPRAY OR HOW ARE OTHERS PULLING A LOT OF TIMING THANKS FOR ANY HELP
Dig 7 here as well. If you have a stock style distributor, you don't want to take anything over 12 or so degrees out with just a box due to crossfiring. You might just want to set your initial lower.
Discussion Starter · #4 ·
OK ITS A SBC SPRAYING 500 WANT TO LEAVE ON 350 HP AND 1.5 SECONDS LATER START PHASING IN ANOTHER 150HP BY 3 SECONDS HAVE ALL 500 HP IN BUT WANT A BOX THAT WILL LET ME PULL TIMING AS THE REST OF THE SPRAY COMES IN TIMING WILL BE 24 INITIAL AND PULL 6 MORE AS THE 150 MORE IS COMING IN ITS AN MSD DIZZY LOCKED OUT
7531 is the way to go
I could be wrong but I believe the 7531 is not allowed in NHRA competition and other venues like PSCA, Street Car Super Nationals, etc. So just check to make sure. I use a Mallory HyFire VIIc, which is fully legal, can pull timing on up to 3 stages and then put some back in if you want near the end of your run. Also has 3 RPM limiters (burn-out, high end, transbrake).
Lots of people ARE using the 7531 in PSCA, SCSN race etc. Some NHRA events they are not allowed but there are a ton of them out there being used. We've used one for the past 4 years...a great ignition that's got a lot of features. Ours is integrated in with Speedwire nitrous controllers and has worked flawlessly.
SOFA KING WHAT?
You may want to think about a crank trigger also.
1 - 12 of 12 Posts
