1 - 2 of 2 Posts
new 706 4.84 bore space 11.680 deck 4.600 bore 5.300 stroke 18 degree brodix big duke heads pb1802 built for lots of spray all new don't have cam card here but 14.5 compression sheet metal intake with split dominators two induction solution foggers not installed by steve just purchased from him. first kit .026n .020f 5.5 fp second kit .032n .024f 5.5 fp only goin to spray first kit until get it lined out base timing 30 degrees on motor where should I be on .026 jet ?? thanks for replies
First kit only 26n - start with total of 20 degrees and check all plugs after the run.....check the strap for heat (should be running ngk11).....bet you'll end up at about 22-23 degrees once it's 'tuned' in.
1 - 2 of 2 Posts
