1 - 6 of 6 Posts
Whats the best way to pull out timing when using a edelbrock progressive thinking about using a digital 7 box
Connect the Pink wire of your 7530T box to the +12v timer output your progressive controller. Then you need to go into the tree and program in the 1st stage retard for the amount you want. If you plan on running a 2nd stage connect that to the Violet wire and program that also. You will also need to program the +12v timer output in your programmed controller box.
1 - 6 of 6 Posts
