1 - 5 of 5 Posts
Alright fellas I currently have a 8762 boost timing retarding my timing from 35 down to 23. Degrees. That's on 8 psi..I'm looking to push more boost around 12-14. How would you all suggest I set my timing if I do so.? And how much should I retard it to?
PS...my car is intercooled And has a csu 750 carb
Thanks in advance!!!
Need more info. Compression ratio, cylinder heads, cam, possibly IAT's and definitely fuel type. Also what did your plugs read like at 23 degrees and 8psi. If at 8.5:1 on pump gas and 8psi there shouldn't ever be a need to pull as much as 8 degrees.
compression ratio is "supposed" to be 9.5:1...i say that cause i bought the car and was told a few lies....heads are vic jr, i was told it was a roller but its hydraulic, and i usually run 93. at the track i run 3 gal of 112 with one gal of 93. my afr's read low 11's at WOT, mid 13-14 idle and a bit lean at cruise around 15, the way its setup now ....not to worried about afr's but i was looking at timing numbers for when i add boost. i wanna make around 12lbs and dunno if i need to keep my timing set at 35 degrees and retard it down to low 20's or wat i need to do:confused:
You shouldn't need to pull that much timing, I'd say you are safe to ramp it down to 24 or so with some race gas in there.
So I should keep my initial timing around 35-36 an retard 1-1.5 degrees per pound of boost...I guess Wat I'm getting at is do I need to up my starting point or retard more down below 20 degrees on 14lbs? Like I said earlier I am retarding 1.5 right now on 8psi...starting at 35 degrees ending around 23 degrees..
im always running 93 or 112 and most of the time its mixed
1 - 5 of 5 Posts
