1 - 3 of 3 Posts
www.429-460.com
How do you guys go thru and ck you timing maps/files from a digital 7 ?
lauch sequence all the way down to the run ? i want to make sure i set everything correctly before i make a pass ...
thxs for the input
Nick
If you have your computer hooked up to the Digital 7 you can read it live (real time).
On the left side under "Monitor" you can see thing such as Launch go from on to off when you hit your launch/tranny brake button. If you want to cycle it thru you need a MSD 8998 tester. That takes place of your crank trigger and cam sync.
http://www.msdignition.com/product.aspx?id=4777&terms=8998
1 - 3 of 3 Posts
