1 - 6 of 6 Posts
My car has a New FAST XFI
Programable Digital 6 with HVC 2 coil #8253
When I try to check the timing the light will flash even with
the inductive pick up not even connected to a spark plug wire????
The light says it is rated for DIS ignitions and convetinal ign??
It is a Inativa 3551 not advance type light just the basic timing light??
Any ideal :confused:
Ive tried Mac and Snap-on lights. The only one I have that works with my 7AL3 and HVC-2 is a cheap Craftsman advance timing light.
I have the same setup, Dig6, FAST, and coil. My timing light works just like it should. I have the Equus Pro Digital Timing Light 5568. Could it be a bad plug wire, jumping spark?
I agree. When there is a bad plug wire the coil secondary voltage (and corresponding flyback voltage in the primary) rises to the maximum it can produce. The result is a more vigorous emission (transmitting) of radio energy from the broken wire, which is acting as the transmitting antenna. Use a pocket sized radio set to receive on AM and move it around near the plug wires. It should make the loudest popping sound near the bad wire.
Thanks for the info
1 - 6 of 6 Posts
