1 - 10 of 10 Posts
I know that this question is a bit difficult but there are good people who can make a rough calculation on ... pro-built 6.0 chassis lamb front, electric konis rear, 3.70 rear, 33.5 tires;
Weight 2525 pounds, P-glide Big Dog 1.80 straigtcut Coan, mega-series split-conv.custom,
The engine is a 706cui stroke 5,3/ 4.600 bore, Dart 18-degree cylinder heads, camshaft Fulton, twin 1250 pro-series holly.
The engine was dyno 1180 hp and have a avreg between 4500-7800 at 1060 hp, it is twin TNW Fogger sys
tems and the first stage is F33-N40 at 5.5 psi and second-F28-N31 at 5.0 psi. I assume that the track is good and the engine sits in a good car and I know it's hard but I think there are people who have roughly the same set. I answer questions if you have any .... :) so time to sec stage ?
we have almost the same set up as that. we ran a 36 30 and a 34 28. the car ran 6.65 211 mph. we had it soft on the front, but with that speed we think the car will run a mid 50.
its a glide with a 180 first. on a really good track, we can turn it on at .4 in. the issue is its on the egde.
1 - 10 of 10 Posts
