1 - 5 of 5 Posts
Do I remove shims to bring the stator closer to the turbine and add removed shims to the underneith of the turbine?
Make the stator closer to the turbine...The shims that you remove place between turbine and drive cover..leave at least 1 shim on each side of the bearing..
thanks man thats exactly what I did! next question my convertor was to tight any idea what a 1 shim move will change it. currently I have only the torrington bearing and 1 shim between them. and 5 shims between the drive cover?
I can't remember right but I think it's 100 a shim...
1 - 5 of 5 Posts
