1 - 3 of 3 Posts
i posted this in the trash section but just incase some dont go there. anyone using the foot control on there machine?? i just got one and if i press down slightly it turns on. it will control amp adjustment but there in no way to stop except pulling the torch away. problem with that is the foot control stops working for like 5 minutes. with the finger control i can start, weld it hit the button and turn it off then immediately turn it back on. reason for this is change of position going around some 1 1/4 ms roll bar tubin
there is no info there on the pedal. i actually got the fitting off of one of those guys to run a regular hose
1 - 3 of 3 Posts
