1 - 9 of 9 Posts
sn95 body style. Would it be ok to use 1-5/8 round tubing 134 wall with a plate under the bottom to connect subframes? And could i weld in brackets to put the X pattern under the bottom With grade 8 bolts? Would this be strong and work as designed? This is a stock suspension car with exhaust turndowns at rear end.
fabricator
It all depends on how fast you are going. For your average street car, yes that is fine. If you are a above average car, then I like to go through the floor and weld to more of the floor. The through the floor is stronger. However, I do like that you are wanting to put in a X-brace with it. Are you welding the subframe connectors and then making the X-brace bolt in with brackets?
yes im welding suframes. This is goin to be a mid to low 6 sec car. DOnt think it will be any faster
Sho'Nuff
if you're going to use that heavy .134" then do yourself a favor and bevel the ends so that you can get more weld penetration.
Discussion Starter · #7 ·
I was going to notch all the tubing at the welds. All welds are goin to be clean. No ugly stuff on my car.. lol. Is there a differ tubing u would recommend for this job??
1 - 9 of 9 Posts
