Throttle pedal for 68 camaro.
1394 Views 9 Replies 6 Participants Last post by  z289sec
Who makes a good throttle pedal assembly for a 68 camaro. I still have the stock one with solid linkage not a cable. Would like to go with a cable style or modify my existing one.
1 - 10 of 10 Posts
i made mine but i saw these if they help you.
http://smithracecraft.com.previewmysite.com/cgi-bin/online/storepro.php
well the link doesnt take you righ there but you can find them in the camaro section.
The Smith Racecraft one is flat out kick ass. It's a direct bolt-in and functions flawlessly.
why do you want a cable ? i think the rod style is better, no strech and positive throttle return. We make one that has a taller billiet arm for taller intakes and plates,a billiet plate with bushing tube that goes thru the fire wall
The Smith one fits mine with a Super Victor, a nitrous plate, and a two inch spacer and has plenty of room for more. I agree with the above poster.....why would you want a cable system?
We have taken the cable off all our cars. Mine worked fine for a million years.
My buddies have had a lot of trouble that last couple of years, so we all switched.
by the way, i use a linkage also, better pedal feel and you can pull it back if it sticks and you have a toe hook, i would recommend the linkage over the cable.
Rod linkage is the only way to go IMO. Actually got a customers 68 Camaro that has a cable system that is giving him fits with hanging up in its inner sleeve. Its coming off this week and a Smith Racecraft one is going on in its place.
Thanks for the responses! Looked at the Smith Racecraft pedal think thats what ill go with...,
You won't be disappointed.
1 - 10 of 10 Posts
