I searched and found a thread in the turbo section that talked about this a little, but not quite enough.
I'm looking at putting a P1SC kit on my '98 Ram V10 (8.0L). I'm just going with the 8psi kit to help with towing. Exhaust is a no-brainer but on the intake side it turns out the V10 uses the same TB as a 5.2.
What confuses me is the TBs are flowed using vaccuum, not boost. If the procharger puts out 1200 cfm max, which of these TB's would you guys suggest? A little smaller to retain velocity or bigger to allow max air through there? :smt102 These are my options:
980cfm
1050cfm
1100cfm
I've never messed with forced induction before, so your help is appreciated. Thanks!
980cfm
1050cfm
1100cfm
