1 - 6 of 6 Posts
Kelly's Nightmare
In a screw type blower bow much does throttle body size affect boost/performance.
I have to step it down in size to meet the rules will it lower the boost will i have to spin it faster?
Don't confuse boost with volume. Boost (measured in PSI) is a function of back pressure, ie; air that is NOT going past the intake manifold or into the engine. Volume (measured in CFM) is the amount of air that IS getting in. I assume that your supercharger is "sucking" air through the throttle body, and since velocity is usually not an issue with that format, use the "tits and nipples" formula (bigger is usually better). What size do your rules permit. Accufab offers "race" versions in several sizes, that have the ability to move more air without going up to the next size.
Kelly's Nightmare
I have a 105mm but rules say no larger than 80mm
thats why i was asking, since it will have a smaller area to suck through it would creat less boost at the same blower rpm with the 80mm than with the 105
a properly shapped 80mm throttle body could flow as much or more as a straight barreled 105.
Talk with a company like the one George works at. They do make some "Race Special" stuff that has alot more science in it and is designed the applications such as yours.
I would talk to accufab.
1 - 6 of 6 Posts
